Post your latest oil change
2004 F-150 5.4 3V 148K Out: Pennzoil Platinum 5W-20 Filter: Motorcraft FL-820S OCI: 7k In: Pennzoil Platinum 5W-20 Filter: Purolator PSL24651 OCI: 8-10k
2002 Chevy Malibu Mobil 1 5w-30 Fram Tough Guard oil filter 1 bottle of Techron added to fuel tank 7500 mile oci Out: Same as above
2003 Honda Civic LX AT 39,315 miles SuperTech ST3593A Mobil Super 5000 5w20 This last run was longer than my usual- ~9,500 miles, about a year ago I ran synthetic. About this "Maint Req'd" light: it goes off every certain number of miles, correct? Any advice on my oil change schedule/which oil I should use? The car sits for most of the year as I live in a bicycle-friendly neighborhood. But I'd like to keep it sharp. I felt bad with the extended OCI because of the synthetic, but was that appropriate? Thanks.
2001 Mazda 626 V6 137,250 miles Out: Castrol GTX HM 10w30, Denso Filter In: Castrol GTX HM 10w30, Microguard Filter Miles on oil: 4,000 Main rear seal is still leaking, but the GTX HM has slowed it to the point of not being an issue, or at least not worth the money to fix. Over 4,000 miles I used 1/2 quart of oil.
2010 Chevrolet Traverse AWD Current Mileage: 52,587km (32,676 mi) Most recent OCI: 4 months and 8672km (5388mi) with OLM showing 47% Drained: MotoMaster Formula 1 Synthentic (4.4L) + 1L M1 5W30 Filled: Formula Shell Conventional Oil 5W30 Filter OFF: ACDelco PF48 Filter ON: ACDelco PF48
2010 Ford Fusion Sport 59k Out: Amsoil XL 5w-20, Motorcraft filter In: Pennzoil Ultra 5w-20, Fram Ultra 5%OLM/1yr OCI 2005 Lexus IS300 125k Out: Mobil 1 5w-30 EP, Bosch Distance+ In: 2qt Toyota 0w-20, 3.7qt Mobil 1 0w-40, Purolator Synthetic 7500/9month OCI 1998 Dodge Neon SOHC 156k+ Out: Pennzoil High Mileage 5w-30, Purolator Classic In: Valvoline Conventional 5w-30, Purolator Classic 4 month OCI 1996 Nissan Sentra 1.6L 150k Out: ???, Fram Extra guard In: Valvoline Conventional 5w-30, Fram Tough Guard 5000/6month OCI
2006 Nissan Altima 103K: Out: Castrol 5w-30,Nissan filter,4K OCI In: Valvoline 5w-30 WB, Nissan filter KingCraft 3250 Generator: Out: Oreillys 10w-30 80+hrs In: Peak 10w-30 2005 Silverado 77K: Out: Motorcraft 5w-30,Motorcraft filter...dealership $22.95 special In: Valvoline 10w-30 WB, Purolator filter
2004 Jeep Grand Cherokee I-6, 107k Out: Castrol GTX High Mileage winter blend of 5w20/5w30, MoS2, Motorcraft FL-400S. In: Quaker State Defy 5w30, MoS2 and Fram Tough Guard TG3600. Fourth consecutive OCI with MoS2, UOA pending.
1986 vw campmobile. 1.9l H4 watercooled. in: summer blend; 3 qts shell rotella 15w40 + 1.5 qts kendall semi synth 10w40ish (1 qt 5w30, half qt 10w50) out, 1 gal of winter blend 30 weightish, at 163700 mi. memo: next due at 168k
2013 Sonata 2.4L in: 5W20 VWB ($12.88 WM deal), out PP 5W20 ($19.88 WM deal), OC @ 12,789 kms, next OC due at 18,000 kms. OEM Hyundai filter. On the Hyundai Canada 4 month or 6,000 km OCI interval. So far VWB as smooth and as noise free as the PP.
2004 Highlander: Out: 4 quarts QSUD 5w30 Napa Gold Filter In: 4 quarts frankenbrew - Mix of .5qt 5w20 PZ, 1qt QSUD 5w30, 1qt T6 5w40, and the remaining Chevron 5w30. (Thinking of going straight T6, opinions?) Also D/F Auto trans - 3 quarts maxlife ATF, and D/F power steering with Maxfilfe ATF too 142,374 Miles on Vehicle.
Just changed my '13 Hyundai Tucson GLS today with Pennzoil Platinum and a Hyundai oil filter. I ended up picking up 0W-20 and didn't realize that it called for 5W-20 until I had already drained the oil. Oh well, I don't think it will hurt anything and I'll go with 5W-20 next time.
