I'm getting tired of high gas prices and $20 worth of fuel giving me only 1/2 tank more in a 16 gallon tank. I hear both good and bad things about LPG. The good things I hear are long engine life, clean emissions and just less wear and tear on the motor and keeping the oil cleaner, longer.
Some bad things I have heard are the smell like rotten eggs which I'm ok with, less responsive due to the lesser BTU's in propane than of gasoline and range.
I'm not too highly concerned with range since it seems LPG is available most places that do sell LPG.
Some conversion kits don't cost much. I was doing some research on LPG last night and found some kits to range $150-$200. I also like the conversion kit doesn't seem all that hard to do, at least with my skill level anyway.
However, I am also unsure if I should do this because in a couple years or so, I do plan on doing a 5.0L V8swap into my truck so the propane for it's longevity would be useless to me. I have seen and heard you can swap propane kits from your old ride to your new vehicle. What gets me is the little things such as needing more hose, the right fittings etc...
While I am unsure of my decision I do want to ask for those who have converted to LPG or have an LPG vehicle from the factory, do you like the way your vehicle performs? How is performance? Has your vehicle been low maintence for you? etc... Thank you,,,,,AR
