Might need to replace the torque converter on my 06 Saturn Vue V6 and the manual says trans comes out the bottom together with the engine. Without a lift, how doable is this? Getting it high enough off the ground shouldn't be a problem, but what to use to lower everything including the subframe to the ground? A transmission jack just isn't wide enough to support all that. What about one of these hydraulic tables? https://www.jegs.com/i/JEGS/555/814...ea1RTZxFr934vA_DcIFlJt6xwnMz9cBUaAh1gEALw_wcB
