positive Pri-G results
NC
Vehicle: 06 silverado H.O 5.3L V8 (L33) This truck is tuned for 89 octane fuel. It definitely rolls out when you stomp it. Since it has been tuned, about four months, it would ping at and above 3500 rpm. Ive ran 89 octane, 93 octane, a mixture of both, different fuel adds, etc. Nothing would cure the pinging at high rpm. And Im quite sure there is little carbon internally to cause pre ignition. Two days ago I bought and added the recommended dose of 1oz per 16gal of Pri-G in 89 octane. Today I hammered on it and there was no pinging, so I got on it again. Still no pinging which is nice. I have to think 'Pri-G is highly effective at reducing pinging' as the bottle states.
How was it "tuned" for 89 octane? A Hypertech reprogramming or a dealer reflash for a TSB? Sorta hard to adjust the distributor for less timing advance when there is no distributor or anything else adjustable for that matter.
I installed a tuned PCM which was 'built' for my driving style after mapping driving around town and at WOT via EfiLive. I was given a choice if I wanted to stay with 87, or progressively more aggressive tunes (89, 91, 93octane).
could be overheat too. I'd say upping the coolant with some redline or amsoil coolant thingys...?
