Polaris 330 ATV oil filter equiv replacment?
Jupiter, Florida
I have a Polaris trailboss 330. It is a Robin engine with a spin on filter with p/n 3084963 printed on the can. In any case, I would like to know of a locally available filter that will fit. Do you guys know which filter is the same? It looks to be about the same size as my JD tractor filter.
Chris
That a 20mm filter common to Honda, Nissan, Subaru, Kia, Hyundai, Mitsubishi........ Plenty of choices. Try the 6607/7317/3593 sized filters.
Chris
Aren't these engines made by Fuji Industries, not Robin?
The Wix 51358 is the correct filter. There is a Napa Gold 1358 that I have used on my Sportsman. They are about $10.
There's a finer choice if you can handle the length. 51356
Part Number: 51356
UPC Number: 765809513563
Principal Application: Acura (02-06), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-06), Infiniti/Nissan (96-06), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-06), Saturn (04-06), Outboard Marine Engines, Various HD Equip.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 363
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
