Pneumatic grease gun
Originally Posted By: hansj3
Why high pressure? If the zerk is clogged, replace it
Usually it is not the zerk that clogs, rather the small grease passages inside the component being greased. High pressure helps in these situations.
A pneumatic grease gun is a little higher pressure than a lever grease gun and a lot higher than a trigger grease gun.
They do have tools to deal with stuck zerks. Typically a tool to blast some penetrating oil into the zerk with a hammer blow.
