Iridiums have been factory installed in some non turbo, non supercharged engines for a least the last 12 years. GM LS engines get them. I would not modify the gap on an Iridium plug. They use fine-wire technology and are not meant to be adjusted.
thank you for reply,
for engines whose OEM plugs are copper, is it safe to use iridium considering heat range??
both platinum & iridium use fine wire technology. but do you think installing 1.1mm or 1.0mm gap plugs will not cause misfire as originals plugs is 0.8mm ??
what's the damage could happen if fine wire plugs got gap adjusted??
Both mine and my parents Caliber's came with copper plugs, we put iridium plugs in both and they are still running great. The finer point or iridium and platinum plugs make them easier to fire, so a 0.2 to 0.3mm difference is negated by that.
My 2011 Durango with the 5.7 HEMI, which uses 2 plugs per cylinder, came with copper plugs. I put platinum plugs in that and it always ran great.
You risk breaking the fine points of the iridium or platinum plugs by adjusting them, which is why they say not to gap them.
