pink coolant for 2001 camry
Richmond, VA
he should never be allowed on BITOG if he waited 8 years to drain his coolant....and no the green stuff doesn't mix with the green stuff. Ask him if he has ever had pink shots and green shots in the same night, you are just asking for trouble.
Louisiana
2001 Toyota's that I have seen came with Toyota RED. I have 2003 Sequioa that came with Red. I was told by dealer (not saying he knows all) not to switch it to PINK. I have two 2005 that came with the pre mix Pink.
[RT] ProjUltraZ
Honolulu, HI
ok i'll ask him to check the manual. it looked more pink but i'm not used to toyota coolant. i'm betting he can use the super long life pink or the peak global lifetime, buy enough and have his mechanic flush it if he can give up his radiator drains
St. Louis, Missouri
Not sure, but I think they say Toyota pink can replace Toyota red. But Toyota red should not be used to replace pink. (Don't hold me liable for any gasket leaks, though.)
Bill in Utah
Staff member
UT
The way I understand it is Pink is 50/50 of Red. Red is 100% coolant and must be mixed. Do NOT add anything to Pink. Bill
St. Louis, Missouri
Heh heh. Red is Long Life, and pink is Super Long Life :-) We don't wanna confuse the Toyota newbies :-) The factory fill of pink is suppose to be good for 100,000 miles or 10 years. Thereafter, refills of pink are suppose to be good for only 50,000 miles or 5 years. I think the red needs to be changed every 2 or 3 years. Not sure, but red might actually work better than pink, but red doesn't last as long and has to be changed more frequently.
