guys looking for some advice on my 96 Jimmy 4.3l. been having problems with pinging and a slightly rough idle.
Here is what has been changed in the last 6 months. plugs, plug wires, cap rotor, O2 sensor, coolant temp sensor,
egr valve, tps. figured the egr and tps were the issue. the egr when checked was sticking and the tps was broke
inside when I removed it to check it. they were original on the truck and had 90,000 on them.the rest of my changes
were done as regular maintenance. I run fp every tank 1oz / 5 gallons of gas. tried adding BG44k to the tank before
my oil change. the idle has improved a little but it is still not where it used to be. at first figured the pinging was due to gas quality being poor. have moved up to 89, little change and even 93 does not cure it completely. any ideas what
may be causing the problem ? maybe MAS sensor ? the idle is not terrible but the pinging is horrible to listen to. thanks for any ideas you may have.
