Okay, my o2 sensor/cat con odyssey with my 02 CR-V....
1.Began getting front 02 sensor voltage CELs
2.Began getting cat converter inefficiency CELs
3. Priced Honda parts and got weak-kneed
4.Ordered parts from Rock Auto for $400
5.Snapped bolt from cat to exhaust manifold
6.Had shop drill out bolt and install cat for $300
7.Still got CEL after installing a Bosch universal front o2 sensor
8. Ordered 2 "OEM" DENSO sensors from dealer on eBay (Global-automotive)for $60
9. Installed this new front O2 sensor
10.New "OEM" sensor was not OEM, caused dramatic inrease in fuel consumption
11. Ordered REAL OEM Denso direct fit sensor from RockAuto for $163.
12. Installed and now all is good...
This is the first time I've ever seen a situation where only the OEM part would cure the ill. At least I got by without a Honda cat. Those were priced anywhere from $1-1400 depending on where you bought them. So I don't feel that bad...
If this DENSO sensor had not worked, there might have been a Fit or Cobalt in my garage by the weekend. But all appears right now...
Now, on to new brakes...
