It will increase. IF We postulate that heat is added isothermally (s-l-o-w-l-y). Angular momentum is the integral of angular velocity times mass from the center of the cylinder to the outside surface. As we compress the gas the mass increases and the angular momentum. This the simple solution. But the problem is that may be impossible to compress it isothermally.
The reasons for this is that the gas movement is not frictionless and although the "heat of pressure" can be removed isothermally the friction of gas molecules dictate that heat will go away (isothermally) but in the process the velocity will slow down and the anguler momentum will decrease.
But also note even before pressure is added it will slow down due to this phenomenon.
In effect you would have to make the outlandish assumption that molecule movement is frictionless. The other reason there is no correct solution is that it violates the Second Law. lol..I'll check back tomorrow. I suspect that the OP already knows this.
