OK this is one of those beer & napkin discussions. My friend swears it's true, but I disagree. (I think his wheels have come off and he's heading for the ditch!). But I digress . . .
"One" is viewing a tire from the side as it travels down a level road. (Vehicle & size don't matter, though I'll say the tire diameter is 2 feet). One puts a LED on the center of the tire and another on the outer edge. So as the tire travels down the road, one sees a straight horizontal line and another of circular arcs. Assume no slippage between tire and road and constant velocity.
My friend says that since there is no slippage and the ground isn't moving, that the velocity of the tire when it contacts the road (at 6 o'clock) is zero. Further, the velocity of the tire is max when it's at the top (12 o'clock). So the tire velocity increases from 0 to max and then decreases back to 0 as the LED on the tire moves from 6 o'clock to 12 and back to 6. And that this 'average' is summed up, resulting in the linear velocity of the wheel moving in a straight line (the LED on the axle).
I say: No-Way-Jose.
Since velocity is constant, one part of the tire can't have a velocity of 0 while 180 degrees from it, the velocity is max. V must be the same at every point along the circumference of the tire. In other words, there is no 'special' point. Furthermore, acceleration is zero and so is torque because the car is coasting at constant V on a level, smooth road. (Ignore wind resistance).
He retorts that there is a special point: The one in contact with the ground and if the ground isn't moving, neither can the tire, as there is no slippage. Therefore, it's V must be zero.
I retort that the vehicle/bicycle is moving forward and every point of the tire contacts the road as the wheel turns AND that angular velocity of the tire is constant since acceleration is zero. I think the principle of conservation of angular momentum applies here.
He also made another point about the wheel...something...force..but I forgot as it didn't make sense either.
I searched on a couple of physics forums, but just found the standard questions/problems.
So what say you? Anyone heard of this physics problem before? Please weigh in.....
