gathermewool
Site Donor 2023
I disassembled the razor because the battery was dead and the charger showed bad battery. I force charger the battery for five min at 4VDC using a bench-top power supply, which resulted in around 0.7A. The battery now shows 3.477VDC. I get the same voltage on the other side of the board, at the soldered locations.
The issue is that when I check the tabs that actually connect to the charger I get nothing at all. I had to actually pull the cover off and connect alligator clips to the tabs directly attached to the battery to force a charge.
So, the large solder on each side of the board shows battery voltage (it’s soldered through the board to the tabs directly connected to each side of the battery. The solder on the left side of the pic (reverse side of the board to the battery), near the button, is positive. On the opposite side, the large solder AND the smaller bits that are labeled pos and neg also show full voltage. Ie, positive full voltage is shown with positive lead on the left solder and the negative lead on any of the three on the other side.
What the heck am I missing?
