PF RGT vs Mobil 1
Great video!! One thing- he did not compare RGT to M1 GT. He compared to regular M1.
Originally Posted by krismoriah72
RGT in my stash.. on clearance with rebates. And won the tests. I will sleep well.
I'll 2nd that. Have over 60 quarts RGT smile
You've got me beat, I only have 30 quarts of RGT sitting on my shelf. I really like this oil, my engine uses less on this oil.
RGT 🏁🏁🏁🏁
This is one of those you read only the first and last post, skip the video - and move on ….
Project Farm! grin I actually like the one-armed bandit test, where they measure the wear scar. I estimated the base-oil viscosities for various oils, which can be found here: Base-oil viscosity (full-shear viscosity) of oils Mobil 1 5W-30, Mobil 1 HM 5W-30, and many other Mobil 1 flavors scored rock-bottom in base-oil viscosity. Wear scars in boundary lubrication are affected by the base-oil viscosity. It doesn't surprise me most oils would do better than Mobil 1 in that aspect.
And I will say it again, could care less if I get flamed for it, RGT is buy far the best oil that I have used.....in the sense that you actually feel/hear that the oil is performing as advertised. Startup in morning -20-25 sounded like it had been started as if it was started already, no stress that you would normally hear and I usuallly hear in cold weather starts...such as belt whine etc. Best fuel mileage, and could not belive the quietness. Mind you I also use archoil 6oz. But I have for 3 years in every vehicle. And i have now ran three oci and if anything the performance of my Jeep has risen and drives day/night difference. I have switched oils many times always with archoil, so the variable is the same in that sense. And may have noticed a small difference here and there, but overall....this oil you literally know and feel that this product does what it says.
