Did a search but couldn't find a definitive answer. Will using a hydrogen peroxide solution (3%) for bug removal eat away at any ceramic coating or sealant? My understanding is that it attacks organic substances only.
All I have ever used on bugs is (((HOT-HOT))) water. Don't forget your heavy rubber gloves.
I've never used any chemicals or bug & tar remover. I have however, used some gasoline for tar removal.
I use peroxide on occasion and wax after because it is effective. If you have a high end expensive and professionally applied coating, I might worry but if it is something you applied I would just reapply to the front end.
