I am debating about putting performance friction brand of semi-metallic brake pads on Lincoln LS and F-150 FX4. Has anyone had experience with this pad on these 2 applications?
only review i could find. They are not hawk ,but not much is.at least they are made in the us.
This review is from: Performance Friction 0376.20 Carbon Metallic Brake Pads (Misc.)
I've been having a problem with short lived pads and warping rotors...so I try these using my same rotors(after I turned them) and voila! No more warping rotors so they must help dissipate heat well and they wear very veery SLOW. They are perfectly quiet, I will use them until they don't make them any more.
How well brake pads perform is dependent on SO many thing.
The type and condition of the rotors, calipers and pins, driving conditions, weather, etc..
Therefore some may love a pad, and some condemn it.
They are a great pad compound 97 is what you get over the counter and it's a excellent performing pad with cold brakes & extreme abuse braking. Hard to match performance. I did pads on my Eldo for $33 per axle
