I have a deal pending on a 2013 GM Duramax truck, and the mechanical inspection was just done. Just waiting to get the full written report, but verbally, I have learned there are two big issues:
- Rear differential: fluid is pitch black and full of shavings. Mechanic figures the differential will likely fail sooner rather than later, and that fixing that will run me about $4,000.
- Alternator low output: measured under 12 volts, 11.x volt (forgot the exact figure he said), so it is on it's way out. A $700 bill for that.
I have a $100 deposit with the seller. I am fairly confident he would return the money if I cancelled the purchase.
That said, should I even consider the truck anymore if he knocked the price down to offset these repairs? Waiting for the full report so I can further use any of the small issues found (if any) to use for bargaining if I go that route.
