penzoil ultra in passat?
What specs are recommended in your manual? What specs does PU carry. Need to learn to do a little of your own research... After that we can help.
Originally Posted By: ccapital83
ok so what oil from walmart can i use?
Check out Mobil 0W-40 at WalMart. It meets lots of European spec's. Check their web site, it should give the spec's it meets. Whimsey
It doesnt have to say that, but if you want to go the factory interval you need decent oil. If you were going 5k, maybe you could use another high quality full synthetic, but if its gonna be 10-12k youll need the 502/505. Mobil 0/40 meets 502/505, BMW LL-01, Porsche A40, and Mercedes 229.3, not sure about 229.5 The problem with those motors is the fuel dilution, so you need something to be able to stand up to that.
Great oil, cant comment on its lifespan though. Id play it safe with 5k, but Im sure people can confirm a longer interval.
Google VW 502 00 or VW 505 00 and you will find the complete list of oils that are suitable for your Passat. Popular oils are: Mobil 1 0W40 Castrol Syntec 0W30 ( German Castrol) Castrol Syntec 5W40 PU 5W40 Valvoline 5W40 Kendall GT-1 5W40
