Since I'm coming up on another OCI I figured I'd post this. Engine has APR K04 turbo, High Pressure Fuel Pump, Audi S3 injectors, vent to atmosphere PVC system, plus more. I was running a Driver Motorsports 25psi tune on this UOA and did lots of heavy hard wide open interstate pulls while logging data. Lots of abuse on this oil. I've since switched back to a less aggressive APR 20psi tune to correct some "rich at idle" fuel trim issues.
I found someone else having the same ferrous metal bits in their filter and it went away with no explanations. I changed just the filter at 1k after this and it was almost gone. I'm not too concerned with it right now and will follow up on it with the next change.
As hard as this engine is on oil and the fuel dilution issue I'm having I assumed the 3k interval is recommended as mentioned in the report and since I can no longer do my "Subscribe and Save" on the Penzoil Ultra Euro I need to pick another oil. Since I'm doing 3k changes I was thinking of just trying the Mobil 1 0w40. Not sure if a more expensive oil like Redline would be worth it if I'm sticking to 3k intervals.
Thanks in advanced for comments and concerns
