Pennzoil YB, 5w30, 4,000K, '05 Caravan, 2.4L 4cyl.
MI
2005 (really 04) Caravan, 2.4L 4 cyl.
Pennzoil YB 5w30 Make up oil: 12oz. @ 3K
Miles on Oil: 4,000 (VS. 3K ON FIRST 3)
Miles on Unit:79,000
Warranty over, upped OCI from 3K (Chrysler severe service) to 4K. Winter OCI (Jan. to April). 75% short trips, wife idles to pre-warm. Looking for fuel dilution, etc..
BLACKSTONE COMMENTS: There was a mild rise in iron after the longer oil run......Running this oil 4,000 miles did not harm your engine at all....you could likely run 5,000 miles without any significant changes to engine wear. The oil's TBN was 1.9, so there was still some active additive left for a longer oil run. Oil viscosity was in the 5W/20 range again.
MY COMMENTS: My concern about severe short trip driving in winter were unfounded. Nothing alarming here. Happy camper.
Current/51K/36K/18K......4/09, 6/07, 6/06, 5/05 3k OCI FIRST 3
Aluminum 2/2/1/1
Chromium 0/0/0/0
Iron 9/4/2/6
Copper 2/2/1/1
Lead 0/0/0/0
Tin 1/0/0/0
Molybdenum 5/186/57/263
Nickel 0/0/0/0
Manganese 0/0/0/0
Silver 0/0/0/0
Titanium 0/0/0/0
Potassium 1/0/0/0
Boron 111/41/0/42
Silicon 14/13/8/17
Sodium 3/0/1/2
Calcium 1428/2627/1251/1823
Magnesium 8/6/8/8
Phosphorus 679/663/475/722
Barium 0/0/0/0
SUS Viscosity @ 210*F - 53.1/54.5/53.7/54.5
cST Viscosity @ 100*C - 8.22/8.61/8.38/8.61
Flashpoint in *F - 385/390/410/395
Fuel % - all same
Antifreeze %0.0 - all same
Water - 0.0 all same
Insolubles 0.2% - all same
TBN - 1.9 /(not taken)
Yeah this is boring (which is good for you and your engine!). I would really go 5k oci.
I ran Pennzoil Yellow bottle 5w30 for one oci in my car and it also sheared to a 5w20 but my wear numbers were stellar so thinning out does nothing when it comes to wear metals!!
Originally Posted By: mikeg5
why would that 5w30 shear? the motor or just the nature of the oil?
In my case it is the motor. The 1MZ-FE and 3MZ-FE that's in my engine runs really hot so it does a number on the oil. That is the reason why 1MZ-FE engines had the sludge problem. Hot engines and 7500 mile OCI's Toyota recommended led to sludge because the heat from the engine oxidized the oil.
