- Messages
- 11,006
- Location
- Canberra ACT Australia
Post on USMB Subaru forum as above saying use anything bar 'Pennzoil with their wax based oil'. What is his basis for this which I find kinda strange?
quote:as someone said....'parrafin' is a name that used to be given to wax. PA crude was high in 'nitro-parafinnic' molecules which is not the same thing, but it is close enuf that it sounds scary and uses scary language (to paraphrase George Carlin) In PA where I live, QS and Penn and Wolfs head have been the bane oil of this state for a 100 years. The junkyards are full of cars not there due to gummed up motors, but rather crashes or severe rust.
Originally posted by sprintman: So where are people getting this wax/Pennzoil thing and why only Pennzoil?
quote:Well you know that varnish keeps the non bearing surfaces from rusting don't you.
Originally posted by Drew99GT: Has anyone popped off a valve cover for whatever reason who has been running pennz dino for the life of their motor? I saw the insides of my Dad's 4.3L Blazer which has run on Pennz, mostly 5w-30, and there was no sludge, just a very very light coating of varnish on non-bearing surfaces. Looked fairly clean for over 100K.
quote:Well **** , all those peeps out there with spotless engines running synthetic and no varnish must be pissed now
Originally posted by badnews:quote:Well you know that varnish keeps the non bearing surfaces from rusting don't you.
Originally posted by Drew99GT: Has anyone popped off a valve cover for whatever reason who has been running pennz dino for the life of their motor? I saw the insides of my Dad's 4.3L Blazer which has run on Pennz, mostly 5w-30, and there was no sludge, just a very very light coating of varnish on non-bearing surfaces. Looked fairly clean for over 100K.![]()
quote:I had to replace the head gasket on my truck a few years ago. It had over 20 years and 100K of mostly short trips including moderate winters. For the last 10 years, it was getting fresh Pennzoil 5W-30 dino every 3 months. For a few years in the 80's I was using QS and 6 months intervals until my Pontiac Phoenix sludged up (100K?). I had started it on Pennzoil, but switched. In early 2002, I replaced the head gasket in my 92 Grand Am HO Quad-4 at 180K. After the factory break in, it never saw anything except Pennzoil dino again, every 3 months whether it needed or not. Both engines had some varnish, but little sludge. My conclusion, stick to 3 month intervals, and don't worry about sludge. I blame the Phoneix sludge more on engine design and 6 month intervals than the QS. It was the Chevy short block cut down to a V-6. [ September 11, 2003, 12:39 PM: Message edited by: labman ]
quote:Ive run synthetic in vehicles for 100K's of miles and see the same amount of 'varnish' in there as non synthetic. Of course I actually take motors apart (all engines require an eventual rebuild, regardless of oil used) and Im willing to bet large sums of $$ that the 'amsoil crowd' who claim spotless motors have never actually looked inside any farther than the inside of the oil cap...
Originally posted by Drew99GT: Well **** , all those peeps out there with spotless engines running synthetic and no varnish must be pissed now![]()
Better go get some "varnish" additive from the store so my engine doesn't rust!
