See here:Does anyone know the difference between plain PUP and PUP SRT?
It kinda turned into that. My original question was to ask if PUP is a good oil. Then I realized I had 2 different bottles. I didn’t see that post that says they’re the same thing. Sorry.I thought you just made a thread about this?
Can you elaborate?PUP 0W40 ...it’s not very good
That's interesting...I'm not a Mopar fanboy at all but hard to imagine their engrs are specing a poor lube for stuff like Hellcats.PUP 0W40 (formerly SRT label) is an application specific oil that should only be used for warranty reasons. it’s not very good
zero magCan you elaborate?
What's a "mag"?zero mag
dumpster fire noack
more plastic than kylie jenner
The HEMI is a less demanding application than say a twin turbo Porsche engine where the testing protocol has it lapping the Nurburgring for hours on end. Roller pushrod engines aren't typically super hard on oil and this particular product has a pretty generic non-Euro PCMO additive package, from what we can see from VOA/UOA's, on top of that, the Noack is about the same as a generic 5w-30, which is a fair bit higher than what we see on the Euro oils where it is below 10% (M1 0w-40 is 8.8%).That's interesting...I'm not a Mopar fanboy at all but hard to imagine their engrs are specing a poor lube for stuff like Hellcats.
Given that it won’t make much difference and disregarding the MS-12633 spec, what would be your first choice in a street driven Hellcat? Filter?The HEMI is a less demanding application than say a twin turbo Porsche engine where the testing protocol has it lapping the Nurburgring for hours on end. Roller pushrod engines aren't typically super hard on oil and this particular product has a pretty generic non-Euro PCMO additive package, from what we can see from VOA/UOA's, on top of that, the Noack is about the same as a generic 5w-30, which is a fair bit higher than what we see on the Euro oils where it is below 10% (M1 0w-40 is 8.8%).
GM is now recommending a somewhat similar (M1 ESP 0w-40) oil for the Corvette, an application where they've typically recommended a 15w-50 for track use which has additive levels more similar to a Euro 0w-40. I've also heard that GM's competition Corvette cars typically ran M1 0w-40. We also know it was the oil of choice for many teams at the 24hrs of Sebring.
The more emissions-friendly 0w-40's probably aren't giving up much, if anything, in DD operation where the cars aren't being tracked. On the track, the Euro oils probably result in lower wear at the limit.
I'd say any of the Euro Car(ACEA A3/B4) oils in 0W-40 or 5W-40 or even 0W30 or 5W30, to be ACEA A3/B4 they all have to have a HTHS viscosity above 3.5, and the BMW LL-01 spec that the 5wX oils carry is pretty stringent so is MB 229.5 and Porsche A40 and VW502/505.Given that it won’t make much difference and disregarding the MS-12633 spec, what would be your first choice in a street driven Hellcat? Filter?
Thanks
just the 6.1 factory fillGiven that it won’t make much difference and disregarding the MS-12633 spec, what would be your first choice in a street driven Hellcat? Filter?
Thanks
M1 0w-40 with a FRAM Ultra or similar glass media filter.Given that it won’t make much difference and disregarding the MS-12633 spec, what would be your first choice in a street driven Hellcat? Filter?
Thanks
Take a look at recalls some time and think about that engineers comment.That's interesting...I'm not a Mopar fanboy at all but hard to imagine their engrs are specing a poor lube for stuff like Hellcats.
