Pennzoil Platinum 10w-30 Viscosity & MaxLife
Western Washington
Story 1: I have been trying to convince myself to switch my Mazdaspeed 3 from the factory recommended 5w-30 to 10w-30. I was looking at the viscocity of various oils today at lunch and noticed that Pennzoil Platinum 10w appears to be thinner than Pennzoil Conventional 5w so how could I go wrong. It seems that I could easily show the spec and validate that it was within factory specification if it ever became a warranty issue. I also noticed that the Mobil 1 High Mileage is really thick stuff.
Story 2: Today I changed the oil in my 89 4Runner (engine has about 16k on the rebuild) and opted to switch from Pennzoil Platinum 10w-30 to Maxlife Blend 10w-30 ($14 for a jug). I wanted something a little thicker and since I only managed to squeeze 2,500 miles out of this OCI spending the coin for synthetic doesn't really make sense. Also, the oil pan has a little seep to it because it has a gasket rather than just "goo" like Toyota delivered them. My mechanic said that minor seeping wasn't uncommon when a gasket was used. Ironically, Toyota offers a gasket, but it's not they way they did it.
Any thought?
Story 1- I'm not sure why you want to change from 5w-30 to 10-30, but it won't hurt anything. If it was me I'd stick with 5w-30.
Story 2- Maxlife is great oil, but I prefer Penzoil HM.
Although the viscosity of the 10w-30 Platinum might be thinner at operating temp (100C) initially, it is far more shear stable then the 5w-30 conventional Pennzoil. The difference on paper is minimal - on average, after an interval of running both, the Platinum, being a full synthetic, will likely hold it's viscosity better and end up a bit thicker then the 5w-30. It's so close, it's meaningless though. Something like 10 Cst compared to 15 Cst. of operating temperature viscosity is a meaningful comparison.
If I had a Mazdaspeed 3, given the fuel dilution and shearing issues they have, I'd consider the 10w-30 Platinum over a 5w-30.
Please elaborate why you like the Pennzoil HM better. I'm trying to learn the reason(s) for your preference. I have more experience with the Maxlife, but have some of the PZ to try soon.
It doesn't really matter if you use 5 or 10w30, if your region is quite cold, I would use the 5w30. The 10w30 will be fine though.
Maxlife is a great oil, so is PP.
A 10W-30 will "LIKELY" have a higher HTHS. A 10W-30 will also have fewer VII. A 10W-30 may, often, has a lower 100C cSt than a 5W-30. The 5W-30 will shear more but the rate of shear may have the 5W and the 10W equal at 5000 miles.
If you take Mobil 1 5W-30, it has a 100C cSt of 11.3 and a HTHS of 3.09. Mobil 1 10W-30 has a 100C cSt of 10 but a HTHS of 3.14.
Valvoline MaxLife blend 10W-30 has a 100C cSt of 11.5 and a HTHS of 3.3.
Valvoline MaxLife blend 5W-30 has a 100C cSt of 11.5 and a HTHS of 3.2.
Valvoline Maxlife 5W-30 full synthetic has a 100C cSt of 11.7 and a HTHS of 3.5.
You could run either MaxLife 5W-30 blend or MaxLife full synthetic 5W-30 and actually get a heavier base oil than the majority of 10W-30 oils, conventional of synthetic.
"Also, the oil pan has a little seep to it because it has a gasket rather than just "goo" like Toyota delivered them. My mechanic said that minor seeping wasn't uncommon when a gasket was used. Ironically, Toyota offers a gasket, but it's not they way they did it."
I am confused. Does it or does it not have the mechanic installed gasket?
He is saying it came from the factory with RTV type sealer for a gasket, but that a real gasket has been installed at some point and now has the typical seepage these are known for. At least that's how I read what was said.
It says 5w-30 in the manual for mpg reasons.The precise driving the CAFE testers preform, the visc can make a difference. Not so much for the rest of us.
Yes, it's currently installed with a gasket, but my mechanic said that RTV works better and was actually the original Toyota configuration.
This is exactly the reason I plan to switch to 10w-30.
I'm not saying PZ HM is better than Maxlife. I've just had really good results after using PZ HM in my wife's 97 Maxima, w/ 287k miles, on it and in my 97 chev. P/U, w/ 163k mi., on it. Both Vehicles have small oil leaks and were using a little oil between changes. After I started using PZ HM oil consumption was reduced to practically nothing in my wife's car. I've only been using it my truck for 3 weeks but the oil level is still on the full mark. It usually uses a half quart about every 2 weeks.
