Well, here's the thing:
I recently changed the oil in my truck from Delo 400 to Pennzoil Long-Life (both 15w-40 of course).
With Delo, consumption was very noticeable (never calculated how much, but definitely a good amount).
Now if you take a look at the Long-Life spec. sheet, they say one of the "benefits" of this oil is it "helps reduce oil consumption". Heck, here's a quote from the Pennzoil webpage:
"PureBase® and Pennzoil’s unique Long-Life® additive system that provides a shield against all forms of wear to help extend engine life, reduce oil consumption and provide consistent oil pressure for thorough engine lubrication."
After making the switch to Long-Life, the consumption on my truck has been significantly less.
I can't understand why this is though...what am I missing here??
By the way, it still blows a good puff of blue smoke on startup, so obviously I'm still using oil (yeah bad valve seals
), but not nearly as much as when Delo was in...
[ October 20, 2003, 03:04 PM: Message edited by: Jelly ]
![[Big Grin]](images/icons/grin.gif)
