Appreciate the reply, I’ll give it try and use it for a 5,000 mile oil change…ThanksI've used it. Didn't do a used oil analysis on it, and even if I did, I couldn't tell you if it did well or not. I only ran this oil for 5000 miles, and this oil is designed to go further
Many people with a lot more experience on this site would give you a thumbs up on that choice. I always choose the "Euro" versions if there is a choice, as the Euro versions seem to be spec'd to run for longer intervals (not that I run as long as they say they can run!) than the non-Euro choices. If you happen across the Pennzoil Euro LX 0w30, some people say this is the same as the Shell Ultra Helix, which is highly regarded. If you are sticking with 5000 mile OCI's (like I do), it probably doesn't matter which you use.Appreciate the reply, I’ll give it try and use it for a 5,000 mile oil change…Thanks
The Euro L in the picture.Are you looking at Euro L or the AV as in your picture?
Yes, Just replaced the Pcv system. The ports wasn’t to clogged. I also cleaned the throttle body while servicing the Pcv components…. I had a 2003 Volvo S80 a few years ago, If Volvo only had a normal and easy to replace Pcv valve like other cars…LolThe Euro L should be fine. Volvo requires an A1/B1 in that vintage, but there is a TNN about cleaning sludge that recommends an A3/B4. 5W30 is OK, but your manual will say that a higher viscosity is better for mountains, or towing. Your call on how you use the car.
More I importantly, have you had the PCV system replaced? I mean replaced. The glove test sort of works, but about every 100,000 miles, depending on oil used and interval, the system starts to degrade in performance, and you want it working properly or you’ll see both increased oil consumption and blown cam seals.
Actually, your picture shows the Euro AV on the label...just be sure before you click on "Order", you want the Euro L.The Euro L in the picture.
I didn’t notice…. ThanksActually, your picture shows the Euro AV on the label...just be sure before you click on "Order", you want the Euro L.
I was thinking about running 5W40 but wasn’t sure if anyone used 5w40 in a Volvo.We have owned many white block Volvos. Currently replacing the rear main seals, AT seals and all PCV components on a new to us 1995 850 sedan. See pictures below.
I will run an A3/B4 MB 229.5 0W40 oil. Mobil 1 and then HPL.
Replacing the PCV components in this engine is tedious at best. I’d like to postpone doing it again for long, long time.
