Well, I broke down and purchased some Quicksilver oils (engine/gear) and a Sierra oil filter plus a gear lube pump from a friend I use to work with who now owns a boating supply store/shop.
It's pricey oil, $65.99, for 4 liters up here (I also purchased a single quart) but he did give me a bit of a deal on everything so I can't complain.
I went with the 25W-40 semi synthetic grade as opposed to the 10W-30 as I figured it's highly unlikely I will be boating in any weather 40F or less.
I've watched a couple vids and everything looks straight forward so I have no worries. I plan to run some Seafoam through the fuel system, but I am unsure/uncertain if I should fog it or just spray some down each cylinder? It's an EFI so I assume it likely isn't a good idea to fog it, if I can even do that?
(2007 Merc 90 H/P 4 stroke)
Not sure what else I should do other than the obvious of removing the batteries, clean/coat of wax on boat and engine, grease, etc, but I am open to suggestions.
I am hoping, although not verified yet, to be able to store it indoors? Hopefully I can so I won't have to worry about shrink wrapping it or tarping it.
With it being in storage all winter, likely 7 months, should the engine be tilted all the way down or should I use the factory installed tilt bracket to support it in a semi up position? (proper name escapes me currently?)
What about a transom saver? I will be towing it home approx 125 kms (80 miles) and then obviously returning in the spring for likely many years to come. I've read pros and cons about it years ago but I wonder if that debate has been settled?
Thanks guys.
