PEAK vs QSGB
In the shop
Hello folks. So if you had some of these 2 oils stashed and were debating which to use which one would you pick. I have some PEAK oil and am using the QSGB currently. What say you?
Originally Posted By: car51
Guys, I was just asking which YOU would use.
Answer already given.....the oil you stashed the longest. Simple and concise.
That for me would be the peak but it's in 10w40 and 5w30 grade;)
Whay didn't you give that info in the first place ? In addition, what vehicle is it going in?
Correct me if I'm wrong, but don't those Focuses (Focii?) spec for 5w20 oil? If I _HAD_ to run one of those oils, that would make my choice clear... the 5w30
However, that's only if I had to choose from those 2. If you have the QSGB in 5w20, then that simplifies the choice.
Thanks pbm for letting me know what you would choose
Originally Posted By: Bottom_Feeder
You already own both, so what difference does it make?
This.
I'd prefer QSGB but I'd run either if I had both on hand.
I'd use the Peak during the current warmer wether and go back to the lower viscosity grade QSUD (I'm assuming it is) in the late fall.
A run of 10W-40 Peak in warm weather wouldn't hurt either Focus at all.
You have the stuff, so unless you have other plans for it, you may as well use it.
Originally Posted By: pbm
If both were the same price I'd choose QSGB....
+1
If I had to choose between Peak and QSGB, there's no question I would choose QSGB (even if they were not the same price).
