Patman : Rotella T 5w-40 ?
USA
Hi I have been running M1 10w-30 in my 97 Olds LSS with the L36 3800. I am intrigued by the Rotella T 5w-40. Is this oil ok for my 3800, and does it make sense to replace the M1 with it ? Thanks to you and all others who respond.
Patman
Staff member
Guelph, Ontario
I think it would probably work well in that engine, which is an older design and most likely has looser clearances. Be sure to do a UOA on it so we can see the comparison to M1.
USA
anyone got specs for this oil? Please post. there is plenty of this oil at walmart for $12.83 a gallon. I was thinking this could be the perfect year round oil for me and to decrease my bearing wear. I was also thinking about the 15w-40 pennzoil long life they have for 5.77 a gallon but running in the winter... [I dont know] 92 mits mirage 116k miles, dino entire life
lght1
USA
hi i was just a little concerned about the 5w-40 oil in an engine that calls for 10w-30/5w-30. with its diesel detergents, should keep my engine super clean dont you think?
los angeles
quote:
Originally posted by lght1: hi i was just a little concerned about the 5w-40 oil in an engine that calls for 10w-30/5w-30. with its diesel detergents, should keep my engine super clean dont you think?
Regular changes will also help keep your engine clean.
Iowa
lght, its going to be the next step for my 94 Regal with the 3800, assuming I see an improvement in oil pressure using Havoline hi-mi forumla which is significantly thicker than Hav. syn.
Tn
Mobil 1 is rated B5-02 and CF, so I think detergency and TBN retention are going to be exceptionally good. I would not expect the Rotella to clean any better nor would I run it for an extended oci. I'm not sure we gain anything here by switching. My 3.8 doesn't seem to require anything thicker than M1 10W-30, but perhaps your's might. Only way to know is to compare uoa's and use general impressions as to how each one runs.
MN
someone just posted a great UOA with M1 10w30. I'm not sure why you'd go to a group III. Patman, the 3800 went through a complete overhaul in 95/96, when it became the "series II. This included short skirt pistons, micro finished crankshaft, low tension piston rings, and other high tech features. I don't think the clearances are any looser than most modern engines. -T
Iowa
quote:
the 3800 went through a complete overhaul in 95/96, when it became the "series II. This included short skirt pistons... -T [/QB]
Boo. Booooo. To **** with the short piston skirts and the piston slap they cause.
M1 10w30 in my 3800 = tick tick ticky ticky tick tick tick from the engine audible from a good 8ft away. Switching to Havoline syn 10w30 cut the volume of the ticking drastically, to the point that I cannot even hear it anymore unless the hood is up and I listen closely.
MN
quote:
M1 10w30 in my 3800 = tick tick ticky ticky tick tick tick from the engine audible from a good 8ft away. Switching to Havoline syn 10w30 cut the volume of the ticking drastically, to the point that I cannot even hear it anymore unless the hood is up and I listen closely. [/QB]
Never heard any piston slap out of a 3800. All my 3.8s have run M1 10w30, my dad uses Supertech in his. [I dont know] -T
Tn
Hmmm Forkman, I don't think this is common with the 3.8 engine. I once tried the Havoline Syn and I have run Mobil Blend, GTX, Syntec, and M1. There was no noise like you describe with any of these. All were 10W-30. It's maybe at it's quietest with Syntec (which is even thinner than M1), so... [I dont know] Mine anyway doesn't seem to need more viscosity to quiet things, nor does it consume M1.
Colorado Springs
I recently ran Rotella 5w-40 in my Moms Olds 88, 3800 V-6. It made the lifter tick slightly louder, but other than that, it ran great. Consumption was down a bit, and it turned nasty dark after only about 2,000 miles, so it was obviously cleaning. It also started way easier with the Rotella compared to the dealers bulk 10w-30 in below 0 weather.
USA
quote:
Originally posted by Drew99GT: I recently ran Rotella 5w-40 in my Moms Olds 88, 3800 V-6. It made the lifter tick slightly louder, but other than that, it ran great. Consumption was down a bit, and it turned nasty dark after only about 2,000 miles, so it was obviously cleaning. It also started way easier with the Rotella compared to the dealers bulk 10w-30 in below 0 weather.
so your mom's old had dino it's entire life? then u switched to rotella t syn and there were no leaks? no auto-rx?
KW
Central Arkansas
quote:
Originally posted by blsnelling: Is this Rotella Synthetic friction modified?
Nope not at all. It's just good ol group III oil. I really like the stuff. [Smile]
Colorado Springs
quote:
No leaks what-so-ever. After 2,000 miles, I did start the cleaning phase of Auto-RX with the Rotella for an additional 1500 miles, and it was like black tar coming out when I drained it! Motor is now spotless through the oil fill on the front valve cover. It was prett clean to begin with though.
