I never open up the cooling system unless there's a problem (t'stat, waterpump, etc.). Too many other things to maintain/repair, lol...
If they follow what Toyota does, it would be 10 year initial then 5 year for drain/refill (because you cannot pump out the whole cooling system, some will be in the block and heater core, and put fresh fluid in).I’m thinking GM will be turning Dexcool into a 10 year coolant soon. I could be wrong, but if it happens, I’ll do a a drain and flush, then put in the 10 year version. And God willing I’ll just do a rad drain and 50/50 replenishment in 5 years. No more flushing for me.
While I agree you don’t want to dump it into storm drains or the ground, I’m pretty sure it’s ok to just pour the used and old unused coolant down the sink or toilet drain.For those thinking of doing annual, etc., coolant changes, disposal of used coolant can be a real problem. The locality where I live has a city dump, but that facility does not accept used antifreeze or other vehicle fluids. Other localities require you to be a resident of that city/county to dispose of anything. I can take used motor oil to an auto parts store for disposal, but not used coolant. No one will take that stuff.
You don't want to get caught dumping used antifreeze in storm drains or on the ground. You just don't.
So don't create problems for yourself by changing coolant more often than necessary.
Agreed, I've heard that ethylene glycol is completely harmless (beneficial even?) if the home's wastewater goes to a sewage-treatment plant.While I agree you don’t want to dump it into storm drains or the ground, I’m pretty sure it’s ok to just pour the used and old unused coolant down the sink or toilet drain.
That’s what some cities recommend if I recall correctly
Don't forget that you can still use the concentrate (cheaper) and premix it yourself with distilled water.
