- Joined
- Aug 10, 2024
- Messages
- 10
Part 3 is available here.
Part 2 is available here.
This will be the last entry. I could have gone longer, per the lab, but the fuel dilution was unacceptable for me given the application and how hard this car gets run. The real grim reaper for these cars isn’t the head gasket once that’s been fixed— it’s LSPI. Fuel dilution is not something I’m willing to play with. There’s over 3 quarters of a cup of fuel in the oil at this point.
I took an early sample because the intelligent oil life monitor went off. I was curious to see how accurate that would be.
Quick takeaways are this oil is good, the oil life monitor is surprisingly accurate, and I’ll probably just trust that going forward. That’s not the result I expected.
I’m personally impressed with ~9,000 miles/10 months. Most of the common wisdom from enthusiasts was 3-5k miles for a change interval.
This is a 2.3 EcoBoost DI engine, on a platform already pushing the stock parts to its limit, that’s also tuned, taken to 10 autocross events, and daily driven.
The wear numbers and viscosity/base number remaining are compare favorably to other engines I’ve seen with less miles and much lower oil change intervals. (See here) While my iron numbers are higher, other wear metals are much lower, and titanium is entirely absent. I think the bearings and rings are happy.
Overall, I think Amsoil SS 5w50 holds up very well in this application. Yes it sheared down pretty quickly to 40 weight, but it held there. Motorcraft in other analysis in this engine sheared down to 30 weight within a couple thousand miles. Additive package held up till the end. Boron did deplete faster than the rest. That being said, I would not trust this oil in this platform to make the 15k within a year advertised by Amsoil with this filter/oil combo. Maybe it could have made it. The fuel dilution is out of Amsoil’s control, in fairness.
I’m particularly surprised by the accuracy of the oil life monitor. Many swore this platform had a dummy monitor that just tracks miles. The OEM interval is 1 year / 10k miles. Clearly the monitor saw something in temperatures and service time to call it early. I checked with ForScan and the oil life remaining was actually at 0%. Not an early warning at 10% that would have tracked with it just being a mileage timer.
I’m also happy with the performance of the KN air filter in terms of silicon and dirt.
I am not happy with how much manganese got in the oil from just 3 tanks of race gas/Boostane during autocross events. If I had used it at all 10 events, the numbers would be much higher. I may need to reevaluate the cost/benefit of extra knock protection during hard use versus thoroughly contaminating the oil.
I’ll post further long term updates going forward on the new oil, but it won’t be the same kind of testing frequency. I think I’ll back off to when the monitor shows 50% and 0%.
