Sounds like a great question for the know it all experts with 16,000 posts on BITOG. I'll make the popcorn
snarkSnarky? How so? Please explain 12,249
Lmao. How many have you had?I did not ask you. Or you get your numerous ID's mixed up again?
I've noticed they also have leaking tires when not parked. Does that count?Has anyone noticed that Cars that are parked have leaking tires due to wheel corrosion ?
You got good eyesI've noticed they also have leaking tires when not parked. Does that count?
Sorry....No...Exactly what the title says.I've noticed they also have leaking tires when not parked. Does that count?
From the wheels?If the wheels are rusty, would it not be more accurate to say the air was leaking from the wheels?
If as you state in your title, do you hear them leaking or "assume" they are leaking because you see corrosion?Sorry....No...Exactly what the title says.
Unless you using tubes, tire seals against wheel. If wheels so rusty it causes leaks, why say the tire is leaking, when clearly it is the wheel leaking?From the wheels?
I do not think wheels have the air to leak.
Maybe through? Or more likely precisely on wheel/tire interface and that is bead and bead area, AFAIK.
But if wheel is rusted through or cracked then it will leak through in my limited English, not from.
Krzyś
Because the tire is rubber and it holds air . The wheel is steel or aluminum.Unless you using tubes, tire seals against wheel. If wheels so rusty it causes leaks, why say the tire is leaking, when clearly it is the wheel leaking?
So take away the wheel and how much air will it hold? Nice try, no cigar.Because the tire is rubber and it holds air . The wheel is steel or aluminum.
