Hi - I could use some help with a parasitic draw that my 2015 4Runner suddenly developed. It drains the battery after a couple of days on non-use. This is my 1st time dealing with this issue.
When I disconnect the battery and connect my multimeter inline, the amps fluctuates between 0.475 and 0.575 (on the 10 amp setting).
I’ve narrowed it down to the ecu-b fuse. When I pull the ecu-b fuse the parasitic drain stops. No other fuse on the vehicle affects the parasitic drain.
What should be my next steps? Apparently, the ecu-b controls a lot of things on the vehicle, but I’m not sure the best way to start.
Thanks!
Thanks!
