Painting the inside of a topper?
Minnesota
I've got a 30 year old Eagle topper on my El Camino where the white paint is pealing off the inside of the rough fiberglass. I figure to mechanically remove what will come loose and repaint, but wonder about what type of paint was likely used and then what best to use for the repaint-thanks
Thanks-I ended up using the Zinsser that I had with two coats. Time will tell how it does
