Don't both oxidation as well as nitration occur naturally whenever oil is exposed to air, alas, at a slower rate? Even virgin oil is exposed to air at some point, so I would not expect oxidation and nitration figures to be zero. I think most labs just don't test for it in VOA samples.
That is my suspicion also. I think the heat and combustion process of in-use oil just speed it up. Nevertheless, I might add that Polaris considers oxidation/nitration measured at 20 abs/cm as worthy of flagging as "severity level 1" which just confirms my suspicion that the oil analysis labs are very conservative in "flagging" some of these metrics.
