After conducting a search utilizing Donaldson and Wix filters, I can say that the closest oversize filters for: Wix 51372 are Wix 51592 or Wix 51087
The 51592 is approximately 5.2" inches tall and has the following significant differences from stock:
Nominal micron rating is 16 as opposed to 19 [better]
Burst pressure 25psi lower
Bypass valve rated 18-20psi as opposed to 16psi.
The 51087 is approximately 5.5 inches tall and has the following significant differences from stock:
Burst pressure 80psi higher
Nominal micron rating is 24 as opposed to 24
Bypass valve rated 19psi as opposed to 16psi
Use this information at your own risk. No warranty implied or given.
