^^^While some or rather one 'afaik' OEM Asian AF may use an inhibitor labeled as "plasticizer", zero OEM Asian Phoat AFs use 2eha as inhibitor in their formula. The same goes ALL the true Asian aftermarket AFs (e.g. ZAV, Peak OET). As for sebacate used by Toyota, apparently they made a conscious decision to use it and 'not' 2eha. One could infer Toyota found it to be far less aggressive than 2eha. Whatever the reason, Toyota still maintains the no 2eha as inhibitor for OEM Asian AFs profile and it's worked for them. Even the member commenting this thread on GM air in system, when it came time to choose between a true Asian Phoat AF and current Prestone with 2eha, chose the former as explained
HERE. This much certain, as long as the OEM Asian AFs avoid use of 2eha, no vehicle I maintain calling for Asian Phoat as spec will see an AF using 2eha.
It would be interesting to see an 'authoritative' citing/citings, study/studies proving as posited, that GM cooling systems using original green AF failed at the same rate as those using DexCool. That said and said before, I've got no problem with DexCool in modern cooling systems that now spec it as their AF. In other words, cooling systems now designed for its use.
Back to topic, I agree with the comment(s) suggesting use a coolant combustion gas test(er) to see if head gasket is the issue.
