Ok, changed the ZJ's oil Tuesday, realized I used the wrong weight Wed and drained it and refilled with the right stuff. I noticed today that there is a huge puddle of fresh oil under the Jeep. The drain plug area is dry, it is all coming from the rear main seal. I didn't drain the filter when I redid the oil, just pulled the plug and drained it, and then put in the full 6 quarts. The dipstick reads over the safe mark by about a half inch.
Would the excess oil be blowing out the rear main seal and will it quit with the excess is removed? I have been keeping an eye on the dipstick level to make sure it doesn't leak out a dangerous amount.
TIA
Edit: Jeep has 86K on it so rear main will need to be replaced soon anyway
TIA
