There is, but the bypass valve is a few ticks higher, iirc.
It's also for a Ford
FORD 785F-6714-AA3A
Part Number: 51087
UPC Number: 765809510876
Principal Application: Ford European-Dorset Engs.
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.477
Outer Diameter Top: 3.661
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 19
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 355
Max Flow Rate: 11-13 GPM
Nominal Micron Rating: 25
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Here's the regular in WIX
Part Number: 51372
UPC Number: 765809513723
Principal Application: Ford/Lincoln/Mercury (91-09), Mazda (00-09), Cadillac STS-V, XLR-V (06-09)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.167
Outer Diameter Top: 3.668
By-Pass Valve Setting-PSI: 16
Beta Ratio: 2/20=12/25
Burst Pressure-PSI: 275
Nominal Micron Rating: 21
Gasket Diameters
