Yes, AAP sold Product, wish i membered the name, it was a basic epoxy, when you cracked open the package, mixed together, the thing got really hot, even repaired the plastic side tanks on the radiator of my friends Cadillac
I used to have a soldering gun that had an accessory tip that had a fat surface about the size of a dime . I used it to repair plastic parts several times . If you can't find anything like that then the two part epoxy method might work .`
There are a number of JB Weld epoxy products that will work. Forget which I used several years ago on overflow container on my Slingshot but it worked well. The Slingshot used a GM 2.4 motor so it was a typical overflow container. There were a number that developed leaks back then around the seam.
