- Messages
- 2
- Location
- London
We live in the UK and have 2 Fiat Diesels. One is the 1910cc indirect injection Punto. The other is a 1910cc Doblo, common rail, turbo diesel.( Both this years model)
Fiat specify 10w 40 to ACEA B3.
The dealer uses 10w 40 Castrol Magnatec
cut & Paste
( Magnatec)PERFORMANCE RATINGS
API SL / CF ACEA A3-98 / B3-98 MB 229.1 VW 505.00
meets requirements of VW 500/501
CHARACTERISTICS
SAE Viscosity Rating 10W-40
Density at 15°C, 0.875 g/ml
Viscosity at 40°C, 104mm²/s Viscosity at 100°C, 14.5 mm²/s
Viscosity Index 144
Pour Point -36°C Closed flash point 195ºC
TBN 8.7
Chlorine Level - less than 50 parts per million
However....
I have discovered theres another Castrol 10w 40, Enduron.
cut & Paste
(Enduron) SAE 10W-40
Relative Density at 15ºC ISO 3675 / ASTM D1298 g/cm3 0.87
Viscosity at 40ºC ISO 3104 / ASTM D445 mm2/s 89
Viscosity at 100ºC ISO 3104 / ASTM D445 mm2/s 13.3
Viscosity Index ISO 2909 / ASTM D2270 - 151
CCS -20ºC ASTM D5293 mPa.s 3300
Total Base Number ASTM D2896 mgKOH/g 18
Flash Point (COC) ISO 2592 / ASTM D92 0C 236
Pour Point ISO 3016 / ASTM D97 0C -42
Sulphated Ash ISO 3687 / ASTM D874 %m 2.0
I would be most grateful for opinions as to which of these two oils I should use and why?
The change intervals are 6,000 miles on the Punto and 12,000 on the Doblo. This is on Magnatec at the dealers. Thanks in advance for any help, Regards, Mike
