Originally Posted By: Ben99GT
Originally Posted By: CATERHAM
I know Dave pushes their 5W-20; call me cynical but I think the reason is the much higher profit margin on that oil vs their superior and more expensive to formulate 0W-20.
I think Dave pushes it because he sees 5W-20 as a more suitable "hard use" oil than 0W-20, which is what Red Line is really all about.
For most V8s give me the 5W-20 any day. I'd MUCH rather a 3.3 HTHS oil when I'm going WOT on a 100 degree day with 7000 lbs hooked up to the truck, which is way more common for me than a sub-zero cold start. My truck doesn't even have a factory oil cooler.
If 5W-20 has an HTHS of 3.3 then I have two questions:
1) Why need 0W-20? HTHS of 3.3 seems like it would keep wear nice and in control in most engines.
2) What is the fuss over a low VI? Does it matter? Does that not mean that the oil "changes' more from cold to hot, but it being a special 5W-20 more akin to a 30 with much better flow properties than a 5w30, does it matter?
Makes me want to put a quart of 5W-20 in with the 5.0's next fill. It does well on its 5w30, but i like what i am reading regarding wear and heat. the only question is this 0W-20 grade they have..
Surely, this 5W-20 is virtually the same as their 0W-20 in Texas heat, in an engine i want to keep for a long time, having just come off heavier oils with this new thinking about how the engine is actually lubricated?
