I just turned in a Patriot rental car from Hertz here in Denver.
I did not like it.
It's cheap in every sense of the word. It has a decent, if a bit bouncy, ride. The driver position for me was uncomfortable because of the non-adjustable wheel (tilt only). If I were shorter, then it might be OK. The seats are thinly padded and flat, but not terrible. I've seen worse on the seats.
The engine is coarse and quite weak. They do the typical cheap car throttle mapping so that you get about 75% of the engine's power in the first 25% of throttle pedal movement. Beyond that, there is more noise, but very little forward thrust. It's hard to merge onto a highway with such an underpowered car mated to a transmission that always seems to pick the wrong gear.
Mine was an attractive red color, and it's cute looking (not my style but not bad looking) but I could never own one. It just doesn't drive well (4 banger and six speed).
If you're looking for max interior volume at minimum cost, and you like the looks, it might be for you, but I sure didn't like driving it.
I did not like it.
