Hello all,
Reading the introductory stickies above I'll start with this:
1. What kind of vehicle you have - 2004 Chevrolet Tahoe Z71 5.3L V8
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well - use oil meeting GM6094M 5w-30 or 10w-30 if 5w-30 is not available. Do not use 10w-40 or 20w-50. If exposed to refular tempratures below -29.0*C use 5w-30 synthetic or 0w-30.
3. Where you live - Birmingham, Alabama
4. How you drive (easy? hard? fast? slow?) - fast (70-80 mph, 85 max for short times)
5. What your daily drive is like (short trips? long trips? city? highway?) - 90% Highway, average 90-95 miles a day, 5 days a week.
6. Whether your car has any known problems - only known issues is a ticking lifter on startup that comes and goes, rear main needs to be replaced (scheduled to be replaced later this month when I can get access to lift, oil level checked daily just to be safe, current estimated loss of a third of a quart a week.
If you have any preferences -- synthetic vs. conventional, store-bought vs. ordered online, how long you'd like to go between oil changes, etc. -- or any other info you think might be important, let us know that as well. - prefer synthetic, prefer choices readily available locally, not sure on OCI.
Previous owner(s) neglected an oil change or many, replaced oil pan gasket and cleaned pan and pickup thoroughly. Have had the vehicle for the past 12,000 miles (purchased October 2016) and have used short OCI of around every 2-3 weeks using Valvoline MaxLife HM 5w-30 and WIX or Napa Gold filters to great success of reducing sludge in engine. Excessive, maybe but to me it has helped. Replaced valve cover gaskets at time of oil pan gasket and a little over a month of go replaced the drivers side valve cover (bad fixed orifice tube) and relieved to have seen major reduction of sludge to the point you wouldn't have believed they were the same motor. My original plan was to run the short OCI for 6 months (End in middle of April) and switch to Valvoline MaxLife Full Synthetic HM 5w-30 with Napa Platinum or Purolator Pure one filter. Does anyone see any reason not to swap or should I swap to a different oil weight, and what would a recommended OCI be with this choice? 3000 or 5000? I'm new to the world of there is more than branding when it comes to oil and just seeking some advice and opinions.
Thank you,
Michael
Thank you,
Michael
