What is likely the issue if a still fairly new Honda push mower needs starter fluid? I use ethanol free fuel and it runs smoothly afterward.
Why? It isn't a 2-stroke.Mine does the same thing...new gas, no alcohol, choke works. If it sits for more than a couple days it is impossible to start. I also use 1 ounce tcw-3 per 3 gallons gas.
A local lawnmower repair guy in my neighborhood showed me a trick when my mower had a similar issue. Some carburetors have 3 jets. A "starting " jet and a low vs full power jet. If the smallest jet is clogged it may not start. He uses a welder tip needle tool to clean out the jets.What is likely the issue if a still fairly new Honda push mower needs starter fluid? I use ethanol free fuel and it runs smoothly afterward.
You shouldn't use tcw-3 2 stroke oil. If you want to use jaso fd 2 stroke oil use stuff for air cooled equipment. Tcw-3 is for outboard motors which have water running through them to cool them.Mine does the same thing...new gas, no alcohol, choke works. If it sits for more than a couple days it is impossible to start. I also use 1 ounce tcw-3 per 3 gallons gas.
Yeah i do that with my old 6hp Briggs and Stratton flathead. Put the carb straight up in the air for a few seconds, set it back down and starts right up.I have to tilt my 15 year old Honda on it's front wheels, to get enough gas into the carb to start.
Yeah! I replaced the wax pellet. Didn't solve the issue.
To keep my 2 stroke gas nice and fresh I dump the last bit in the mower. Also if my weedeater gets hard to start, more than 3 pulls, I'll dump the gas in the mowers, air compressor, pressure washer, stump grinder, wood chipper, ect and get all fresh gas in the weed eater or saw.Mine does the same thing...new gas, no alcohol, choke works. If it sits for more than a couple days it is impossible to start. I also use 1 ounce tcw-3 per 3 gallons gas.
How old is the gas in the mower's tank and in your gas
AGREED! Fresh gas will cure an amazing amount of problems.A gas funnel with a screen is another nice option
I hate auto-chokes. It's a decent idea but usually with poor execution. The components wear over time and then the auto-choke becomes finicky, and requires more attention than if the mower just had a manual choke cable to begin with. I've converted quite a few mowers to manual choke for customers, you can find manual choke cables that are long enough on Amazon.I inherited a super low hour Husqvarna mower with a Honda GCV-160. This thing had an automatic choke that would reset after every pull. It took more than several pulls to get it running. I hated this thing and gave it away. One time, it refused to start. I pulled the carb and bowl and found machining debris (a metal sliver) in the main jet (it's a Honda, not a Toyota). Even after this, it remained a hard starter.
I have a +20 year old Craftsman with a GCV-160 with a manual choke. I run E10 in it and it never fails to start on one pull, even after sitting during the winter. I always shut off the fuel and run the carb dry after every use. Fuel is treated with Sta-Bil.
Yeah I wish the Honda hrx had a choke system like the HRC mowers. Or even my old troybilt with gcv160. It just had a lever that you pull and it moves back slowly so you have time to start the engine. Been working for 12 years on mine.I hate auto-chokes. It's a decent idea but usually with poor execution. The components wear over time and then the auto-choke becomes finicky, and requires more attention than if the mower just had a manual choke cable to begin with. I've converted quite a few mowers to manual choke for customers, you can find manual choke cables that are long enough on Amazon.
My favorite system for a small engine is still just a simple primer bulb. 3 pushes of the primer button and then pull the cord, doesn't get any simpler than that.
