Originally Posted by MarkM66
Gravity bleed works well for me.
I've always done the two person method on my Maxima but noted recently in my FSM it says you should disconnect the battery first - presumably so the ABS components are flushed. I would assume gravity method will also flush the ABS components albeit a lot slower? I've always worried about what folks say about the two-person method and also this one person bottle method pushing the MC piston past normal stop points. Even if you use a block of wood under the pedal to prevent a full depression, it will still go past where it would have normally stopped so have been thinking gravity for my next job myself. However, my official FSM does indicate using two-person method on my car FWIW.
