I was at a European car show today and one of the vendors was a guy selling Amsoil and Zymol products. Among his Zymol literature was an oil called Zyntek. I suppose it's manufactured for Zymol but by who? The Zyntek bottles look like shampoo bottles.
Even with a high end $25 oil analysis that's still 15 bucks a quart. The zymol site gives little real information...."meets API SH/SJ, ACEA A1"...yawn, they all do. Anybody heard of this oil before?
[ June 09, 2003, 07:10 PM: Message edited by: rugerman1 ]
quote:http://www.zymol.com/zyntek_copy.gif Each case of five quarts comes with an oil analysis kit for $99.
All run-of-the-mill engine oils are made up of base crude petroleum oil and cleaning additives. Semi-synthetic oils, or blends, are composites of hydrocarbon-processed base stock with conventional mineral base additives. Certain leading "blends" contain as little as 10 percent synthetic oil. Commonly available oil has very unstable short-chain molecules that evaporate or oxidize in the extreme heat of standard engine operating modality. These same oils contain small amounts of sulfur, phosphorus and tar residue that can block small tolerance oil journals causing starvation, overheating and premature engine failure. Zyntek flows at sub-zero temperatures and increases its viscosity parameters as heat and load demands. Each Zyntek Case contains 5 litres of oil and an Engine Oil Analysis Kit. Zyntek is engineered to be perfect.
![[Eek!]](images/icons/shocked.gif)
