olm
texas
I recently bought a 05' buick lesabre custom and it doesn't have an oil change light.I had assumed that all general motors vehicle had that feather,since about 2000.
gary
That's because the oil never needs to be changed... Like their similar design with the transmissions a while back. No dipstick, no drain plug... No need to change. Sleep easy brother!
Maybe it's not available on that model because they are revising it?
gary
Read your Manual.
It does have either a light or a display with the OLM percentage on it when you scroll.
Take care, bill
Bill,the manual has info on vehicles with the DIC option which showes the percentage of oil life remaining.However my vehicle does not have the DIC option so the manual has no info on the olm in base models.
gary
gary
Then it has to have a light. Call Buick up on their 800 number and ask them.
For a long time every GM vehicle has either. My dads Honda powered Vue even has one.
Take care, Bill
I think Bill in Utah is correct. I looked up the online owners manual for you via GM service information and it states the DIC and where to find the OLM. You should have a row of switched on your ip that say: odo/trip, fuel info, gage info, reset and eng/metric.
By the way, here's a copy/paste (read the gauge info part):
GM Service Information
2005 Buick LeSabre | Buick LeSabre Owner Manual | Document ID: 1453669
DIC Controls and Displays
When you turn the ignition on, the DIC will display your DRIVER NUMBER. You can have your GM dealer program your name to appear on this display line. See your GM dealer for more information.
The system will then perform a status check and display any messages if a problem is detected. If there are no problems detected, the display will return to the mode selected by that driver the last time the ignition was turned off.
If a problem is detected, a diagnostic message will appear in the display. The following pages will show the messages you may see on the DIC display.
The message center is continuously updated with the vehicle's performance status.
The following buttons are on the DIC control panel which is located to the left of the steering column:
ODO/TRIP (Odometer/Trip): Press this button for the display to show the total mileage, and Trip 1 or Trip 2 miles. Trip 1 and Trip 2 will display the miles traveled since the last reset. To reset the trip odometer, press the ODO/TRIP button until the preferred trip number (1 or 2) is shown in the DIC display, then press the RESET button. The trip odometer will now accumulate miles until the next reset.
FUEL INFO (Information): Press this button to display fuel information. Press the FUEL INFO button until the display shows FUEL ECONOMY AVERAGE. Average fuel economy is viewed as a long term approximation of your overall driving conditions. To learn the average fuel economy from a new starting point, press the RESET button while the average fuel economy is displayed in the DIC. Press the FUEL INFO button until the display shows FUEL ECONOMY INST. Instantaneous fuel economy varies with your driving conditions, such as acceleration, braking and the grade of the road being traveled. The RESET button does not function in this mode. Press the FUEL INFO button until the display shows FUEL RANGE. The fuel range will calculate the remaining distance you can drive without refueling. This calculation is based on the average fuel economy for the last 25 miles (40.25 km) driven, and the fuel remaining in the fuel tank. The RESET button does not function in this mode.
GAGE INFO (Information): Use this button to display oil pressure, oil life, coolant temperature, tire pressure and battery information. Press the GAGE INFO button until OIL PRESSURE appears in the display. If there are no problems detected with the oil pressure, the display will show OIL PRESSURE NORMAL. If a low oil pressure condition is detected, the display will show OIL PRESSURE LOW. If you see the OIL PRESSURE LOW message, your vehicle could be low on oil or the oil is not going through the engine properly. See your GM dealer for service. Press the GAGE INFO button until COOLANT TEMP appears in the display. If there are no problems detected with the temperature, COOLANT TEMP NORMAL will appear in the display. If the temperature is too high, COOLANT TEMP HOT will appear in the display. If you see the COOLANT TEMP HOT message, the engine is overheated. You should pull off the road, stop your vehicle and turn off your engine as soon as possible. This manual explains what to do. See Engine Overheating . Press the GAGE INFO button until the display shows BATTERY STATE. If the voltage is normal the display will show BATTERY STATE NORMAL. If the voltage drops below 10.5 volts, the display will show BATTERY STATE LOW. If the voltage is above 16.2 volts, the display will show BATTERY STATE HIGH. If the display shows the high or low message, you need to have your battery and charging system checked. See your GM dealer. Press the GAGE INFO button until OIL LIFE INDEX appears in the display. The OIL LIFE INDEX NORMAL display will show an estimate of the oil's remaining useful life. When the oil life index is less than 10 percent, the display will show OIL LIFE INDEX CHANGE OIL. This means service is required for your vehicle. See your GM dealer. In addition to the engine oil life system monitoring the oil life, additional maintenance is recommended in the Maintenance Schedule in this manual. See Part A: Scheduled Maintenance Services and Engine Oil for more information. When you have the oil changed according to the maintenance schedule, you will have to reset the engine oil life system. To reset the engine oil life system, see "How to Reset the Engine Oil Life System" under Engine Oil Life System . Press the GAGE INFO button until TIRE PRESSURE appears in the display. TIRE PRESSURE NORMAL is displayed when the check tire pressure system believes your vehicle's tire pressures are normal. If a potential tire pressure problem is detected, the display will show CHECK TIRE PRESSURE. If you see the CHECK TIRE PRESSURE message, you should stop as soon as you can and check all your tires for damage. If a tire is flat, see If a Tire Goes Flat . Also check the tire pressure in all four tires as soon as you can. See Inflation - Tire Pressure and Check Tire Pressure System . There are times when you will have to reset (calibrate) the Check Tire Pressure System. See Check Tire Pressure System .
RESET: This button, used along with other buttons, will reset system functions.
ENG/MET (English/Metric): Use this button to change the display between English and metric units.
DIC messages can be displayed in one of three languages: English, French or Spanish. The language of the display is set by pressing both the FUEL INFO and RESET buttons for five seconds. As the buttons are held, each language will be displayed for three seconds. Release the FUEL INFO and RESET buttons when the desired language is displayed. All DIC messages will now be in the selected language. Language selection can also be done through the DIC Personal Choice Programming. See "Language Selection" under DIC Vehicle Personalization .
© 2009 General Motors Corporation. All rights reserved.
Sorry - you might be right! Another copy/paste - mentions OLM specifically for DIC models:
2005 Buick LeSabre | Buick LeSabre Owner Manual | Document ID: 1357812
When to Change Engine Oil
If your vehicle has the Engine Oil Life System, it has a computer system that lets you know when to change the engine oil and filter. This is based on engine revolutions and engine temperature, and not on mileage. Based on driving conditions, the mileage at which an oil change will be indicated can vary considerably. For the oil life system to work properly, you must reset the system every time the oil is changed.
When the system has calculated that oil life has been diminished, it will indicate that an oil change is necessary. A CHANGE ENGINE OIL SOON message will come on. Change your oil as soon as possible within the next 600 miles (1 000 km). It is possible that, if you are driving under the best conditions, the oil life system may not indicate that an oil change is necessary for over a year. However, your engine oil and filter must be changed at least once a year and at this time the system must be reset. Your dealer has GM-trained service people who will perform this work using genuine GM parts and reset the system. It is also important to check your oil regularly and keep it at the proper level.
If the system is ever reset accidentally, you must change your oil at 3,000 miles (5 000 km) since your last oil change. Remember to reset the oil life system whenever the oil is changed.
The Engine Oil Life System calculates when to change your engine oil and filter based on vehicle use. Anytime your oil is changed, reset the system so it can calculate when the next oil change is required. If a situation occurs where you change your oil prior to a CHANGE ENGINE OIL SOON message being turned on, reset the system.
Always reset the engine oil life to 100% after every oil change. It will not reset itself. To reset the Engine Oil Life System, do the following:
Display the OIL LIFE INDEX on the DIC.
Press and hold the RESET button on the DIC for more than five seconds. The oil life will change to 100%.
Turn the key to OFF.
If the CHANGE ENGINE OIL SOON message comes back on when you start your vehicle, the Engine Oil Life System has not reset. Repeat the procedure.
What to Do with Used Oil
Used engine oil contains certain elements that may be unhealthy for your skin and could even cause cancer. Do not let used oil stay on your skin for very long. Clean your skin and nails with soap and water, or a good hand cleaner. Wash or properly dispose of clothing or rags containing used engine oil. See the manufacturer's warnings about the use and disposal of oil products.
Used oil can be a threat to the environment. If you change your own oil, be sure to drain all the oil from the filter before disposal. Never dispose of oil by putting it in the trash, pouring it on the ground, into sewers, or into streams or bodies of water. Instead, recycle it by taking it to a place that collects used oil. If you have a problem properly disposing of your used oil, ask your dealer, a service station or a local recycling center for help.
Originally Posted By: SLCraig
Why not just change the oil and keep track of the mileage from that point forward.. Thats all I do.. :)
The OLM is a MUCH more accurate way to model/predict actual OCIs. Static mileage/time intervals rarely account for actual driving conditions. The OLM does an outstanding job of this. Anybody that is OLM equipped should seriously consider it's usefulness.
