Originally Posted By: ExMachina
oldhp and WobblyElvis, Those GM OLMs put a penalty on high-rpm driving. Since you both sound like you're running GM 4-cylinder DI engines on the highway, and I'm assuming you were really moving fast, those 4 cylinders can hit the high-revs often. I got a look at the GM OLM algorithm the other day and noticed that it counts engine revs, and the penalties are severe for cold driving and/or high rpm driving. Of course the cold driving accounts for water getting into the oil, and the high speed driving accounts for blow-by getting higher and pressures-temperatures breaking apart the oil more. .... You get the least penalty for cruising at about 55 mph steady in top gear.
That explains my swift drop in the OLM for my Regal, which has the same engine. I thought I would see little drop on my 2000-mile highway trip to Amarillo last year, but it fell about the same as if I'd driven normally (70% city) for 2 months -- during which I'd usually drive, you guessed it, 2000 miles.
As Celica_XX put it, "We had the same car (GMC Terrain) and if I remember correctly, it would subtract 1% per 61 miles regardless of how the car was driven." That's pretty much what I see.
