Originally Posted by wag123
If it were my car I would change the fluid and filter, put Max Life ATF and Lubegard Red in it, replace the vacuum modulator (because of the other problem), and drive it for a while. What is the worst thing that can happen? You end-up having to rebuild it anyway. But maybe, just maybe, that will take care of the problem. I am a big believer in LubeGard Red. It is one of the few additives that is actually good and actually works, it is definitely NOT snake oil!
If you are worried about metal shavings getting in the ATF, install a Magnefine filter (the real deal, not a knock-off) in the transmission cooler line.
Originally Posted by Fsharp
Whine like that could be from a little air getting into the pump, I'd try changing the fluid and filter first and when you do make sure the new filter seal seats properly there's not an old seal still jammed up in the hole or anything.
Originally Posted by clinebarger
Originally Posted by 007
I had the filter, fluid and pan (ribbed with drain) changed a year ago and no issues until recently. Fluid is not burnt and trans shifts fine.
Change the filter & the O-ring on the filter extension.
Besides the first couple years of production.....The TH400 filter is designed to sit on the bottom of the pan, The Intake is actually on the top of the filter. Aftermarket pans cause all kinds of issues by letting the filter move around.
There ya' go 007!
