The additive chemistry in new oils is very strong.... Every time you change fluids, you disrupt the very thin AW films on wearing surfaces such as cam lobes, valve lifters and cylinder walls. It can take up to 1000-2000 miles for these films (iron-phosphate, iron-borate, iron-moly-sulphur, etc) to fully re-form. During this period, wear under boundary lubrication conditions is measurably increased.
The other effect that contributes to lower wear over longer service intervals is the oxidative thickening process. Oil oxidation results in the formation of higher molecular weight species within the oil that effectively increase it's film strength and viscosity - sort of like using a thicker basestock. It has been proposed by researchers at Ford that these secondary species are also partially responsible with the lower wear rates seen with oils that have been in use for some time.
I should note that most of this discussion relates to rates of valvetrain and ring/cylinder wear, ie the Fe and Cr wear. By and large, engine bearings do best with perfectly clean oil that has lots of TBN reserve to rapidly neutralize organic acids.
So the overall message is somewhat mixed, and things are not as simple as folks searching for some "silver bullet", would like to think.
